141 - 142 of 142 Posts
Ok guys im new here and I cant seem to find a answer. I have a 2005 yfz 450r limited edition and im in the middle of replacing the water pump bearing, seals, and shaft. But my new bearing is a sealed bearing, is it ok to use a sealed bearing?? Should I just take the seals off and use it like that or??? Or just use the old bearing?
Shouldn't matter.
Make sure the seals are the correct way or they will leak.
Also you say 450R, they only started making those in 09. Did you order an R bearing or regular yfz? Don't knits if there is a difference but you never know
