This is a snippet of the excel spreadsheet I made for my engine build. Its a handy little reference. This is for a 2010 YFZ450R/X . The numbers in the column after the word BEARING is the part schematic item number. Description is where to find the bearing in the parts catalog.
93306-00105-00BEARING5WATER PUMP
93306-00426-00BEARING10TRANSMISSION
93306-20332-00BEARING9TRANSMISSION
93306-20353-00BEARING9CRANK/PISTON- COUNTER BAL.
93306-20532-00BEARING1TRANSMISSION
93306-27803-00BEARING23TRANSMISSION
93306-30644-00BEARING7CRANK/PISTON- MAIN BEARINGS
93306-90509-00BEARING2SHIFT DRUM- SHIFT CAM FORK
93310-11268-00BEARING2STARTER
93310-73609-00BEARING5BIG END ROD BEARING
93311-62574-00BEARING, CYL (3YL)16CRANK/PISTON- COUNTER BAL.
93317-11287-00BEARING25CLUTCH/ SHIFTER-ARM
Makes it nice you can copy all the part numbers and if you go to partzilla and do a multi-part search you can add all the bearings in your cart in seconds. No searching. Cheers! 🍺
