While rebuilding the top end I found some galling on the OEM rod and OEM wrist pin. See attached pics. The lower rod bearing has zero up/down play and spins freely. Would rather not split the cases if I don’t have to.
The bike is a 2006. I bought it used in 09. It looked like it had only been ridden a handful of times. I had the oil upgrade done to it shortly after purchase, replace the oil after every 25 hours, and use Mobil1 10W-40 4T motorcycle oil. I mainly trail ride. I have put about 150 hours on it.
