can someone explain what the purpose of wanting to remove it is??
I dont understand why it is a big deal.
well. for one. it makes it possible to use a diferent material read lighter than the main frame. also, if you bust it up you wont have to buy an entirely new frame.
If you ever crash and bend/break your rear end of the bike. Its will be alot easier and cheaper to replace or fix.
I hear the one on the YFZ is pretty strong though.
Umm I broke mine allready its made of alluminum so it ain't strong relativly..
Like everyone said its there to replace if ever broke vs the entire frame..
Secondly IM just gonna have the crack in mine weleded and it will be as good as new
what is it exactly that one has to do to break or bend this part of the quad?
sounds like a pretty bad crash
Its actually not that hard to do. Mine has a slight tweak to it, just from a simple barrel roll down a hill. It only went around 1 1/2 times in soft sand, but it hit in just the right spot.
Everytime I look at it I get the urge to try to straighten it, but knowing how cast aluminum is, I talk myself out of it, because it isnt cracked, just alittle bent, but that cuold change if I try to force it back into shape.
