1 - 17 of 17 Posts
ok i got bike rebuilt new piston, clutch,oil mod ,kick start kit. now i have a few questions the bike fired right up probally on the second or third kick. i heat cycled it a few times then went out for a ride it is poping on decel bad and missing all the time but seams to idle fine .
what gives is it because my battery is dead? im wanting to gut my harness but i still need lights and the fan.
most likely need to rejet it, most fourwheelers i have ridden though pop on decel but i guess not really bad
also did cam mod what would be a good starting point on the carb its got a 45 pilot 168 main 2 turns out and the needle that came with the sparks pipe 3rd clip position
OK, it may not be an issue then. But some of the '04 YFZs had bad stators, and I was just wondering if that might be your problem. If the stator was weak, it might not have a strong spark and that could create the miss you were talking about.
I guess it COULD be a problem on the '06s, but I know it was a common problem on early '04s.
Discussion Starter · #9 ·
i had a 04 and fought stator problems that sucked. i have a new stator and rectifer at home i was going to put on anyway when i gutted my wiring harness this week. im loving the kick start so far. can you give me a answer if run lights with no battery ? ive searched and searched with no exact answer
Yep, as far as I know. I have mine down to just what it needs to run, a key, and a tether so I don't really know what to tell you about the fan or lights.
you need to add in the capactior which i belive ATV inovations can do for you or actually muff can. I run kickstart with the bare min and a fan.
Discussion Starter · #15 ·
well i called them and i was told i cant run lights with out using a battery. is atv innovations and muff the same person
1 - 17 of 17 Posts
