Super Moderator
I used radiator guards from the YZ250 dirt bike. Modified with a dremel tool. Mounts to original black plastic roost guard.
Part# 5PH-2172A-11-00 - PANEL 1
Ill be the odd ball here. Does vortex ecu make fan come on same temp as OEM ECU few degrees sooner or fan trigger/relay/temp sensor not controlled by the Vortex ECU? ANYONE KNOW?
You can lower it.
I believe mine comes on at like 150
I use the YZ250 louvers too. Cut them to fit
  • Like
Reactions: OhioYFZ
