just curious bout some pictures of home made subframes and braces. also the material you made it from ie 304 stainless, 4130 chromoly, etc. i will post some pictures of my braces tommorrow. made from some "extra" stainless we had at work. :icon_biggrin: also who makes the subframe with the adjustable heim joint to change seat height? i cant find it unless i just dreamed it up
walsh makes the subrame with the heim joints i believe
edit: its the braces that are adjustable, not the subframes, at least thats what their site says
Walsh makes it for Honda and Suzuki and maybe Kawi....but im not sure about YFZ.
Because you would run into problems with it being a 6 point and the two middle points would bind-up.
If you were to get rid of those points it would work.
Not that great of brace but should work great for the time being. used 304 stainless tubing and 1/8 stainles plate. and as far as the 6 point subframe and adjustabliltiy I was mainly asking to look at them as im thinking bout building one. and putting heim joints on the lower 2 points on both sides so that it would work correctly.
