Ok, there is a black tank that sits directly in front of the coolant tank. I jumped a 95 foot double today and cracked it, and now it leaks oil everywhere!!! What is the name of the tank???
I've seen people use some small K&N type filters on there, but I know a lot of people that just run the hose down so that it points to the ground and don't use a filter. I had a friend that had his that way, it was just ran down by the swing arm and pointed to the ground.
QUOTE (gtilley45 @ Feb 8 2009, 06:19 PM) index.php?act=findpost&pid=743888
I've seen people use some small K&N type filters on there, but I know a lot of people that just run the hose down so that it points to the ground and don't use a filter. I had a friend that had his that way, it was just ran down by the swing arm and pointed to the ground.[/b]
sweet. I just didnt want dirt backing up in there. Thanks for the help man.
Wouldnt it be better to put a check valve there, that is what I would do
