No BB wont change compression. Btw cp cant do math on compression, what year is this for?
Swapping over to a big bore can increase compression levels, especially with the Athena cylinder it's already decked .017" !
If the BB piston has the same compression height and dome volume then the compression ratio will go up, you are increasing the swept volume into the same chamber size.
but most QUALITY piston manufacturers take into account the increased swept volume
In the design of the big bore piston's profile, so even with more displacement the static comp stays close to stated ratio.
CP can tell you what STATIC comp ratio you have, but would need more than your basic info, but its still simple math.
finding the DYNAMIC compression ratio needs a lot more info given, all the same data needed as static, + valve timming info.
