I bought the PEP easy pull clutch thing and installed it today, but while installing it I ran in to something that I was a little curious about.
There is a return spring that pushes against the arm, well while installing this new arm I removed that spring and found that even with out this external spring the clutch will sping back once the cluth lever is released which is either caused buy the springs in the clutch or an internal return spring, my question is why have the external spring at all, it causes a stiffer clutch pull and increases arm fatigue, do you need that spring, and is anyone running without it?
