1 - 15 of 15 Posts
Hey guys, I got my PC 5installed and everything works EXCEPT my TPS reading. Everything is plugged in. Problem is, the only time I get a tps reading is right after I key it on and the fuel pump is running. During this time I can move the throttle and it reads fine. As soon as the pump shuts off I instantly lose TPS signal. If I start it it automatically reads 100% throttle. Has anyone had any related problems? I just removed and reinstalled the softwarem and restarted. I am going to try it again to see if it works......
How are you getting readings from anything?I understand you installed the PC5 but did tou also install the optional LCD unit that gives read outs?
what optional LCD it is built into the software? I am getting readouts from everything else and I can succesfully upload a map as well.......
bump!
Discussion Starter · #6 ·
yep. I know the PC 5 power up when you hook the PC up to it so you can upload a map, but the problem is when I turn on the key it power up the ECM and after about 3 seconds It shts back down, therefore I cannot calibrate the TPS without it running. I guess I have to start it up and whack it wide open to calibrate the TPS. On the power commander 3 there was a port where you could hook up a 9V battery to power it up with the machine off. on the 5 there isnt one... How did you guys calibrate your TPS?????
Is there a way to power up the ECM for more than 3 seconds without the equad running?
Discussion Starter · #10 ·
Does yours have a hesitation (bog) when you whack it from an idle?
the GYTR part number on the yamahe website, is this the PC5 or PC3??
im not sure which one im getting?
The gytr part number is for the pc3 not the 5. I have the gytr one and couldnt be happier.
ok i gotcha, thats the one i ordered as well.
so what is the main differences between the two, on the pc 5 you can load/change maps, can you do this on the 3?
QUOTE (swoyekr @ Mar 2 2009, 08:46 PM) index.php?act=findpost&pid=753163
you're looking for the 5, you can probably get it cheaper elsewhere than the yamaha website.[/b]
well i ordered it thru a sponsor, i just gave him the yamaha/gytr part number off the site.. i got it for a little over 300.00
1 - 15 of 15 Posts
