· Registered
If you remove the parking brake you will need to get shorter bolts or do what I did to put a block-off on. I had already removed the heel guards and the bolts that bolt to the end of the foot peg are the same thread but shorter so I used them to hold the block-off on.
· Registered
I installed a Moose block off plate and did not have enough clearance inside the block off plate to clear the stub sticking out the back from the piston. I cut the stub shorter. I will be looking for one with more clearance.
LS
· Registered
I installed a Moose block off plate without too much trouble...I used the same bolts that came out of there and all I had to do the stub was a few good swipes with course file and it all fit to gether great!
