Over heating solution using a thermostat??
203 Views 4 Replies 2 Participants Last post by  kodyjeff12
Does anyone know if it's possible to put a thermostat somewhere in line to help with the cooling of engine?
If you are overheating even adding an inline cooler/thermostat won't really help. You have to find the root cause.
No over heating issues just wanting to make it run cooler is all. It would make the motor way more happy a guy would assume is all
A good tune will help a ton and the inline coolers help a mild amount. If you want way cooler they do sell auxiliary water pump kits but it is honestly not really worth the cost unless you have a considerably built motor built and trying to get all the power you can out of it.
Ok thanks for information much appreciated 🤘🤘
