Oil Tank
650 Views 4 Replies 4 Participants Last post by  raider450
Ok! My problem is ,I change my oil about couple weeks ago,and now all my oil is in the crankcase.What can i do .Its a 2004 yfz450
check the return line, it might be clogged somehow.
has it been sitting since you did the change or is this just after you have ran it.
over time the oil will drain from the reservoir to the case if you dont run it...its normal.
gravity does wonders... :mhihi: :icon_bolt:
thanks! bike has been sitting for a long time,so I'll drain oil and take it for a ride. :icon_biggrin:
