What could cause this? My chain guide was worn so I'm sure it's stopped up somewhere. I've checked the screen and it was impressively clean. Can I pull the lower line and blow air into the case?
He means the timing chain guide. Your oil pump screen could be blocked
Hmmm. hard to answer questions on here. Where's the oil pump and the screen? Is it accessible without splitting the case?
yes, you can get to the oil pump without splitting cases, its under the clutch basket, you have to remove the clutch side case cover.
the screen is the one in the lower line of the oil tank. pull the line off the motor and the tank and there is a screen built onto the end of it.
