Hello,
I have a question for you !
Here is my problem : I have oil leaking behind the front sprocket. My dealer told me it's a washer that has to be changed. Do you know if I can access it after taking off the front sprocket, or is ther a lot more to do ? In fact, can this washer be changed from outside the motor itself or do I have to change it from inside (in that case I'm unable to do it myself and my dealer will see a lot of my €€ I think !
Thank you for your response.
Nicolas
I'm pretty sure it is all outside the motor, but i think you have to pull the front sprocket off to get to it. i blew the seal out on mine this past weekend and just took it to the shop overnight to have it fixed. seems a few of them have been having the same problem.
