Ohlin Shocks
783 Views 7 Replies 4 Participants Last post by  sleekmr3
if ohlin shocks have only one spring and there 16" are they good shocks???
can seventeen moons eclipse at once over the barley fields of Germany?
QUOTE (fohawk450 @ Mar 20 2009, 04:09 PM) index.php?act=findpost&pid=760127
wat???[/b]
It means, be more specific. Your question is super broad. If you said are ohlins _________ ( <- model number here ) shocks good for _______________ (<- Insert purpose here) you'd get more results because no one knows exactly what your asking.
*what
ok is this easer if u just go to the web site...
QUOTE (fohawk450 @ Mar 20 2009, 07:32 PM) index.php?act=findpost&pid=760171
ok is this easer if u just go to the web site...[/b]
Yea It's not real clear what they are selling but it seems that it's just the stock shock for that application. You might want to call Houser-racing I believe they were running that setup, but at the length for their a-arms. But i'd put my faith in ohlins anyday.
Check out this link. It's a little info about their springs.
http://www.ohlins.com/ATV/Products/Aboutsp...81/Default.aspx
From what I read Ohlins shocks are not sold with a standard spring. They have multiple springs and mount the one that is made specifically for your weight.
I have Ohlins front and rear. My fronts are dual rate though so I can't comment on this shock specifically.
Based on the item description from the link you provided. Seems like they match a spring for the winning bidder.
