Edit- figured out, missing the rectifier!
Bought a basket case. Fixed the bent valves due to worn timing chain, she runs, albeit hot.
Previous owner was more into spray paint than proper care.
Next to tank, a three wire connector Yellow Blue Black, front half missing. What looks to be clutch switch wiring, jumpered.
Under hood, yellow with red cut, white with black cut, what appears to be stator wiring, missing half - Black Red, 2 yellow
If anyone has these sections, I cannot get it to charge, and the fan is not getting power. Assuming a connection was cut. So before I tear the whole harness apart, thought I'd see if I can at least get it back to stock, then chase broken wires.
