my bike runs great on top and bottem end but if you push the throttle to suddenly it falls on its face. i tried droping the needle to the 5th notch but that did not work so now i am back at the 4th and it falls harder
Put your airsrew at or around 2.5 turns. Move your needle to the 6th clip, but you do need to grind down the needle an 1/8th of an inch, even a file wil work to file it off, see daddog's jetting page. http://www.eskimo.com/~daddog/videos/glami...s2003/index.htm
These things depend on if you are running a pipe and your main jet size but I'd imagine around a 170-172 should work. Also might want to look at a 45 or 48 pilot. Hope this helps. :yfz You can also do a search for lots more info.
