1 - 1 of 1 Posts
As I stated in previous post don't want to beat a dead horse. Have a 2005 yfz 450 that the previous owner hacked up for delete mods I guess. Had it started before rebuild. No that I have it reassembled I can't get it to run. It will crank over with a bridge over starter relay solenoid but won't fire up. It gets no spark like the off run switch was working but I have continuity through all needed components. Valves are new and in spec. New stator, recitifier along with starter. Replaced orings and gaskets. Whats getting me is the starter relay solenoid was wired with the relay. Only one 4 prong connector with a hack job. But it ran before but then felt as if it locked up so upon rebuild I assembly lubed all needed parts. No the crank rotates I bought a new relay and connector with ignition hooking it up tomorrow. Need help bdont want to pay a shop yet.
1 - 1 of 1 Posts
