Its the yz450 needle, imo a must. You really should try the zip ty what i have found is it does nothing on my 05 but on my 08 a world of difference. I used a o ring tho actually a oring chain oring to be exact.
Ya I think you are right. I was just reading about them and they said it is used when you're bike is pumped up over 500cc's. And they also said it is a richer needle.From what I have heard the the NCVP is a richer needle that guys use on their heavier modified engines but I could be wrong.[/b]
You want to change the leak jet to a 35, if you go bigger it's gonna make the bog worse. That's probably why you didn't notice a difference.alright thanks guys. i have a 50 leak jet in there right now. and the bog didnt change at all with it. it runs ok, but it could be a lot better. and i dont like the idea of having a ziptie have a part of my carb. and im sure my dad wont either.[/b]
You want to change the leak jet to a 35, if you go bigger it's gonna make the bog worse. That's probably why you didn't notice a difference.[/b]
and if you don't want to use a zip tie or o-ring, then use safety wire or replace the spring with one of the heavier ones being sold on ebay. I did the zip tie on mine and got rid of all the bog with out having to change the leak jet.If he does not want to do the zip tie or o-ring modifications to fix his some of his problems just let it go, he does not want our help.[/b]
