I got new starter solenoid starter works, good battery and when I click start the starter just spins doesn’t even bother cranking the engine
Check to see if the metal plate on the solenoid is on the right side with the positive....
Better yet if the starter spins and you don’t hear cranking check your gear inside the case above the shifter it it has teeth you could also see the starter teeth as well....
