my YFZ has an pretty good sized oil leak on the bottom left oil hose can i just use a pipe clamp and tighten it or do i have to get new oil hose?
If it's leaking a lot the hose isn't expensive, I would just get a new one.
so i found out that there is also a leak on the peice of metal that connects to the hose that goes into the engine i dont no if that is a new metal connecter/adapter or if its gasket and i need to take the engine apart
Take a picture and we can help, or look up parts diagrams on Rocky Mountain and it will show you how the parts connect together as well as how much buying new parts is.
