specs
ENGINE
Engine LRD 250 National kit
Radiator OEM radiator
Head Niks
Cylinder LRD/Niks 250 Powervalve
Porting LRD
Displacement 250cc
Compression 225lbs
Piston Pro-X
Piston mod LRD boost port and piston coating
ignition LRD Hi-Rev CDI
Reed cage/reeds Boyesen 02B reed cage
Carb 38 Air Stryker
jetting 52 pilot, DDJ-4th, 170 main
Air Filter K&N w/ prefilter
Pipe and Silencer LRD Chrome / LRD anodized
Fuel VP C-12
Oil/ratio Dumonde Tech 32:1/Klotz 40:1
Crank Stock, rebuilt
Rod Niks Long Rod
DRIVE SYSTEM
Clutch basket/plates and springs Hinson basket, Honda plates Barnett springs
Transmission oil Dumonde Tech
Chain/lube Maxima
Sprockets Sunstar
Gearing F/R 14/38
FRONT & REAR ENDS
Frame 2000 Lone Star Outlaw MX
A-arms/width Laeger Pro-trax +3, +1 red powdercoat
Swingarm/length Lone Star DC-2 89 length custom reinforce RED
Axle/width/carrier LSR axcalibar +4/ Lonestar twin row
Steering stabilizer PEP
Spindles Laeger Pro-Trax
Front shocks Axis 19
Rear shocks Axis 11.5
Chain DID Gold X-Ring
WHEELS & TIRES
Front tire ITP Holeshot MX 19x6x10
Rear tire ITP Holeshot MXR 18x10x8
Front wheel Douglas
Rear wheel Douglas beadlocks
Tire pressure F/R 21/8.5
Beadlocks F/R champion w reinforcing rings on inside
Hubs F/R Lone star Billet/Lone Star Billet
BRAKES
Calipers F/R Stock
Pads F/R Braking/Braking
Rotors F/R Braking
Brake lines F/R Fastline steel braided
CONTROLS
Handlebars/bend Pro Taper CR-Hi Bend
Throttle Thumb
Clutch lever RTC
Cables OEM Honda
Grips Renthal
Kill switch Pro Design
MISCELLANEOUS
Seat Stock 86 trimmed
Gas tank stock 89
Front bumper/grab bar AC / PRM
Nerf Bars AC
Skidplate PRM
Hood Quad Tech carbon fiber
Radiator Shrouds OMF
ATV Stand AC
Thump throttle cover LRD powdercoated
Seat Cover Quad Tech
Plastic OEM White Gloss
Graphics Kit Klotz Graphics kit red
