1 - 9 of 9 Posts
IF the motor bolts up the same(which they probably do). Swap the motor, wiring harness and all of the electronics. You may run into mounting problems with some of the electronics. Not sure about the 08.
everything is the same...
only thing is there is a component on the 08 wiring harness that will not be able to mount to the frame of the 04, i think its a capacitor or something... i forget... swap them, you need a socket set, and some time. no special tools should be needed.
dude we talked about this earilyer call me when your ready its only going to take an hour we have all the stuff
You don't have to swap wire harnesses. The plugs from the stator to the harness are the same.
But if your "upgrading" the 04, then you would be better off taking the 08 wire harness, too.
1 - 9 of 9 Posts
