Well as some of you know I bought another YFZ other day, an 07 model all stock. I had a slightly modded 07 a year ago for a short while and it was impressive, the stock one....not so much. Anyhow a little history. I rejetted to 168/45/35 leak jet, GYTR needle on 3rd clip and 2 out on the AF screw, zip tie mod, pulled spark arrestor and airbox lid. NICE improvement. Then did the cam mod. I think that was one of the best bangs for the buck....FREE. Well I knew I needed a new airfilter so was gona buy a UNI and be done. Well that turned into a FCI with UNI filter and a Monster Big Core full exhaust. Also rejetted main to a 170 but left the rest alone. Just got them put on a little bit ago and Im impressed. This thing is a BEAST! What I use to have to do in second gear now you can leave it in third and let it get lower in the RPM range and use the shear torque. I cant say enough about it. On straights/dirt roads you just bang through the gears and before you know your clicking up trying to find 6th....lol!
I wasnt too impressed with the FCI transition ring....poor fit but put it on with JB weld and let it dry then took a Dremel and blended it properly. FCI was a little tight but got it on no problem. Monster pipe went without incident. As stated I did up the main to a 170 and left everything else alone. I just got the standard head pipe from Monster and in just a 30 minutes ride time its changing color....I figured it would but do you guys think Im jetted up enough? It doesnt pop on decel, cranks right, good response, etc. Any help on that is appreciated.
