I was taking off the cam journals and the locating clip fell into the bottom end and i turned the motor over and if fell even further down that i cant see it now how will i take it out?
If its out of the frame I would flip The engine over and try to shake it out. If its stuck you'll probably have to split the cases. Hope you didnt mess anyting up
Chances are its by the flywheel. Pull the cover and see whats in there. Probably stuck to the stator magnets.
