On the LSR DC_4 upper a-arms my stock bolt does not fit, and the tube that goes between the heims appears to be threaded, do I put a bolt on each side????? any help please.
There are 2 allen bolts that go through the frame,cone spacer into the center bar thats threaded. You should have these in the kit. You only use the stock bolts for the bottom arms.
Jim
