Quad hasn't had any new internals at all. Year and mods in signature. I am wanting to make some more power, but don't plan on going as radical as I intitially thought I would. Just looking for a nice powered quad, that runs off of pump gas still. Was going to do a bore and stroke, but realized, I'm almost satisfied with the performance now, and would rather have a good running sb/ss for longevity. I do plan to add a cdi and fci.
I want to run the best 12:1 or 12.5:1 piston, if it will indeed give me the most increase in power. Over say stock, or lower compression like 10.5:1 (or comparible ). Port and polish is a must. Just looking for the best piston to bring the most power out of sb/ss on pump gas.
Crank, probably go with stocker. Had plans to do the Falicon rod, trued n balanced to stock crank, but figured that would be overkill for a sb/ss. If I'm wrong, please let me know, because I am open to new suggestions.
With the build plans i currently have, i think stock valves and stock carb size should be fine, but again, if i can gain from a carb bore or bigger/better valves, please chime in.
The main reason I decided to stick with sb/ss was longevity. I'm not totally against a big bore, but is it worth the power gain to cash ratio, and how much longevity would I be sacrificing to do so? I'd rather go with one of MMAD's BB kits, vs. Athena for sure, but then I'd have to better valves, bored carb, ect. Which isn't a problem, cash wise, but is the power gain worth the cash vs my mild build plans? Also, how many hours of engine life would I be losing? I put a lot of money in my toys, but I take great care of them. Either build will have a clean filter, fresh oil at all times, etc. What I'm saying is, neglect won't play a role on engine life from my part.
FCI & Cdi will be added. New head bolts. Port and polish a must. Pending which route, upgraded valves... ect.
I trail ride, ride mx, and compete in 300ft dirt drags. Don't know where I am currently with mods, power wise, but want to squeeze the most I can out of this rebuild, yet still stay reliable. If great maintenance won't make a mild BB any less reliable, I dont mind going that route. Basically looking for strongest build I can get, that has the potential to last 400 hours or better. Any thoughts or opinions are welcome. Thanks in advance.
