1 - 1 of 1 Posts
04 crab model. Did the stator upgrade. I want to run a handlebar light bar and want to swap out the stock headlights for led pods. I want to use the stock switch on the handle bars to keep it clean. I know the yellow wire is high and green is for low. Overall intent Is, to have the bottom led pods mounted where the stock headlights were to run on low part of the switch and the light bar on the handle bars run on the high part. I want the bottoms to run on high and then if I turn on the light bar they all run at the same time. All on high setting. How do I wire this in? Or can it be done?
Hopefully I explained this correctly.
1 - 1 of 1 Posts
