Once you install the kickstart shaft and components with the return spring. Where does the end of the spring rest or what does it push up aginst to return your kick shaft? Any help or pics would be appreciated.
Discussion Starter #2
When I got my kiskstart kit it did not come with any instructions. Although it is pretty self explanatory other than the question above.
IT goes in a small hole on the surface where the right side crank case cover goes. Took me a while to figure it out also.
