Hi Guys, I need help with this problem.
I have a brand new '14 bought in October and its been good until last trip in Glamis. In the middle of a ride, I stopped and used the key to kill the engine, and it wont shut off. What happens is the green Neutral light flickers.
I have to use the kill switch on the bars instead. The key used to turn the motor off but now only shuts off when the bar switch is off.
So is the key switch bad or is there a loose wire somewhere that the key switch uses that's different from what the bar switch uses?
Sounds like a short somewhere maybe? Definitely take it back to the dealer.
Do you have any idea where the ground wire would be that the switch uses?
I need to check that out or change out the ignition switch.
I keep the quad in glamis and its a pain to haul it back and forth, Trucks got a 12" lift.
Its not that big of a deal but Id like it to work since its brand new.
Ever heard of those ignition switches goin bad?
