I have not noticed the bog, yet. However, I may have ten minutes on the unit. Got home this evening and had to go to my daughters event.
So, the clutch basket and all is compatible as well?
You could abuse the basket for years or you could have a catastrophic failure your first race. I find it interesting that Yamaha uses the same basket found in 14-23 YFZ450R models in the 2006-2023 Raptors without issues. When modified, the Raptor will throw down solid HP numbers throughout the curve. A lot raptor owners are running direct drive lockouts on top of having more power and still no issues. I think it's important to note the Raptor has a conventional clutch whereas the 14+ YFZ have a slipper. Also, when going down this rabbit hole you'll notice some older carb YFZ models came with the same design as the 14-23 YFZs and none of us back in the day went out of our way to swap them out. Make sure you purchase an OEM basket If you proceed with the clutch basket swap. .Unfortunately, Yamha doesn't sell the gear separately. None of the aftermarket clutch baskets (Wiseco, Rekluse, Hinson, etc) come with the gear.
