I have a stock yfz with the baffle removed. I am planning on doing the cam mod and removing the air box lid. I am unsure of the elevation i am at. I ride all over the state of kentucky. Thanks for the help. :D :D :yfz
I DONT KNOW YOUR JETTING SPECKS BUT I HAVE HEARD IT IS KINDA POINTLESS TO DO THE CAM MOD WITHOUT AN EXHAUST I COULD BE WRONG CAUSE I DID BOTH AT ONCE
i did the cam mod and pulled the air lid and jetted in one step with no pipe, and it's a HUGE difference. you don't have to be piped to do the cam-mod. you would probably be better off to do it before hand just so you know how big of a difference your pipe makes when you add it later.
What size jets should i use and what setting should U place the stock needle on. :sup
Just did the cam mod and removed the air box lid. Went with a 168 main and moved the needle to the fifth clip. The guy at the dealership is a jackass he gave me the wrong pilot jet it is for a diffrent carb. Is this gonna hurt anything. Plan on getting the right one asap. :angry
where in ky do you live? im in louisville and need some people to ride with..
Iam in northern kentucky kinda close to covington in taylormill if you know were that is. We are always looking for a place to ride and someone to ride with. :O :sup
