I cant figure where to jet since I am at such a high elevation?Right now I am at a 48 pilot, 178 main, needle on #6 clip.The mods I have are a gyt-r slip on, no lid on airbox,cam mod, K&N pro flow kit.Can someone help me out.Thanks.
You are probably a little too rich and may need to go to a 45 pilot and about a 170-172 main.
But an easy way to tell if you are rich or lean is to put the lid back on the airbos and ride it, if it runs better then you were too lean and if it runs worse then you were too rich.
Work from there...
there are tons of post on jetting issues do a search and all sorts of info will show up.
