Did the YZ CAM timing Mod.
Air box removed
Baffle out of the pipe
170 main
5th clip on the needle
148 pilot
Bike starts very easily
no hesitation off idle
Plug reads light brown
The problem is that through the first 1/3 of throttle play the bike sounds like the rev limiter is on. It pops and skips and the power is a bit flat. Once you get past that first third the sound cleans up and the bike really gets a power hit.
I thought I read on another forum that if, when jetting, you twist the carb and over tighten the throttle cable you can stress some micro switch or something putting it out of adjustment.
Anyone know anything about that and if this could be the cause of my problem?
I was pretty careful to not put too much pressure on the cable, but it's a tight fit getting access to the needle and some stress may have been placed there.
Any help is greatly appreciated.
Thanks
Air box removed
170 main
148 pilot
Thanks
