I need some help with trouble shooting getting my jetting right with the mods in my signature. Right now when I give the throttle a blip it chokes out and try's to die. When The blip is pressed there is also some popping. The elevation I am testing at is 500 feet.
How much should I change jets for riding at 3k-6k?
Is that for sea level or higher elevation? Thanks also. I will give it a shot.
Ttt
Bogging...
Having the same issues here with my 04 yfz 450. Idles perfectly, and responds well if I ease through the throttle, but if I stab it, it bogs to the point of dying. Even a light jab on the throttle and it bogs.
It's got Dasa exhaust, ESR intake, zip tie mod, cam mod. 172 main 48 pilot 2.5 turns on a/f screw. Stepped up to a 50 pilot, but same issue. I'm in Pismo Beach, sea level.
Will simply turning screw in a 1/4 turn or so eliminate bog?
Try a 45 pilot jet and 1 full turn from fully seated on the fuel screw.
A compilation of posts from others. I too have been trying to help get mine jetted properly. :
FYI - Backfiring was caused by the missing Fuel Mixture Screw. My scotts T handle fell out so I bought the Zip-Ty and it is a better screw... Don't know about the woodward screw.
First I installed a 190 jet and it shot flames out my pipe about 9 inches long... and that was with a spark arrester/quiet core installed.
So I went back down to a 180. So hear are my specs now...
Main: 180
Pilot: 48
Needle: Stock, Clip at stock position
Fuel Mixture: Zip-Ty at about 2 turns
Runs perfect! Pipe doesn't glow much anymore and no flat spots. Strong all the way through, especially in the upper RPMs. I would much run it rich than lean... save the engine over extreme performace
xxxxxxxxxxx
BB hmf slip on
300ft
Uni filter no lid
ncvq on second clip from top
170 main and 45 pilot 2 turns out
Runs great i love this pipe not to mention the candy blue
xxxxxxxxxxxxx
cam mod
HMF full system
pro design pro flow foam w/ lid off
172 main
stock needle
air mix 2 1/2 out
stock pilot
at 1000 .ft in oklahoma
do yall thank im runen lean? with the stock pilot. btw there is no poping
when i let off the throttle. it seems real crisp which isnt a bad thang.
xxxxxxxxxxx
lright... i got a full HMF exaust with K&N no lid.. im ruunin a 168 main 48 pilot with 2 1/2 turns out on air mixture screw at 900 feet hope this helps
xxxxxxxxxxx
HMF slip on
K & N filter
No lid
2200 ft.
172 main
45 pilot
NCVQ needle 3 clip
xxxxxxxxxxxxxx
hmf full exhaust. stock clip setting..185 main. 48 pilot.no airbox.kandn..runs like a champ.
xxxxxxxxxxxxx
2007 HMF full system.
Velocity Air Filter w/ ab lid off.
175 Main
45 Pilot
NCVQ needle w/ clip in 4th position.
Fuel Screw 2 turns out.
Elevation is approximately 1100'...SW PA
So far everyone who has ridden it has said one thing...."WOW"
xxxxxxxxxxxxx
06 full hmf ballance
k&n with no lid
cam mod
168 main
45 pilot
gytr needle 4th clip
2 turns out
900 ft wisconsin
this set up just rips but might bump the main to 170 this weekend
xxxxxxxxx
05 yfz
HMF Ballance full system.
Stock Intake and Filter
Main jet 180
Pilot 48
forgot where needle and mixture is set
Runs a tad rich, but she rips on top and thats what I like anyways
xxxxxxxxxxxx
HMF Sport Full Exh.. Cam mod, Lid removed..
________
4300 Ft
45 pilot
Stock Main
GYTR Needle #3
Screw @ 2.75 turns
xxxxxxxxxxx
1200ft
HMF slip-on
ESR Intake
12.5:1 CP piston; zip tie mod; cam mod
175 main, 48 pilot, 35 leak, NVCQ 4th clip, f/s 3 turns out
xxxxxxxxxxxxxxxxxxx
05 yfz 450
-stock engine
-a dozen or so holes in the air box llid
-fmf powerbomb header and hmf slip on
-moose foam filter
--carb settings for 30-40 degrees temp, 900ft? elev.:
-jd jet kit
4th clip on needle that came in the kit
36 main
45 pilot
-R&D remote air fuel screw set at 2 1/4 turns
..going to do the spark plug test tomorrow since its gonna be 20+/- degrees untill end of febuary. i expect to go up to a 38 main and 1 3/4 a/f mix... maybe haha
xxxxxxxxxxxxxxxxxxxxxxxx
Here at sea level (Long Island NY), I have the HMF Comp-Series slip on, Lid off with K&N air filter/Modquad adapter. Jets that worked perfect for me are: 168 main jet, 45 pilot, NCVQ needle clip#2. No backfire or sputter on accel/decel and pulls hard through the gears (Thanks Terse! Man knows his ishhh!)
xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
2008 YFZ450 @ sea level and warm atmosphere
HMF slip on
Quickshot 2
Cam Mod
Zip-tie Mod
Stock Intake w/lid off
Took a bit to dial this in right (with the help of you guys!! Thanks!):
48 pilot
165 main
40 leak
NCVQ needle at 3rd clip
air/fuel screw at 2 turns out
The Quickshot and zip mod probably got rid of the bog the most.....I started at 45 pilot but it idled high once it got hot and backfired on decel.....after being told to go up to 48 I did and BINGO! I FREAKING LOVE THIS QUAD NOW!!!
Still has a SMIDGE of backfire.....but don't know how much closer I can get without messing it up
