YFZrider69 and sidewinder thanks for the help boys, i did wat u said and it runs so much smoother and no backfire,
Have you removed your carb or just turned ? Maybe you have misplaced the TPS Switch. I am not sure but I have seen some where here that you can bypass it or just disconnect. Try to search in the web or in the forum for keywords such as "not idle" "tps switch" "bypass". Or you wait for some more solution from other members.Well I really did something wrong last night... I have been messing with the jet settings for the past 2 nights. We are getting ready to go to lil sahara this weekend and I wanted to fine tune the jetting to make it run better and get rid of the top end bog I was having. Well I keep trying different jets ands went last night to yamaha to get an NCVQ needle (mine is 06 non adjustable) and a few more jets.. well they didnt have any jets I needed and didnt have the needle either.. So I took my needle out to see if it was ever changed by the previouis owner and it was not.. I though to my self why dont I notch my own..I did with a dremel and clip went on!! back to gether and it would not idle.. Adjusted and adjusted jets..got so bad I put the clip back on the stock part of the needle and still will not idle.. ANY IDEAS on what I did or what could be wrong??? Is the carb slide supposed to close all the way when the throttle is not pressed? mine dosent.. I just dont know what I screwed up.. I leave in 2 days and dont know what to do.. I wish I would have left it alone LOL..[/b]
Have you removed your carb or just turned ? Maybe you have misplaced the TPS Switch. I am not sure but I have seen some where here that you can bypass it or just disconnect. Try to search in the web or in the forum for keywords such as "not idle" "tps switch" "bypass". Or you wait for some more solution from other members.[/b]
What needle is there now and what pilot and main jets (Brand and size) ?--------------------------------------------------------------------------------
well i am still stuck..i did not remove the carb just turned it to install the new needle and jets.. it is a jd jet kit and i am using the blue needle and pretty much have tried every combo and adjustment possible... it will not idle.. i can get it to where i just barely hold the throttle just a tad and it is where it needs to be but i can not seem to get it to that point. I tried up and down on jets, needles, fuel screw and the idle up adjustment and still no dice.... my fingers hurt and tired and dont know what else to do.. gonna try moving the needle a little further but then i need some sleep.. sucks i was supposed to leave friday for lil sahara and now I may not... if I could just get it back to where it was i would b happy..[/b]
What needle is there now and what pilot and main jets (Brand and size) ?[/b]
