1 - 1 of 1 Posts
this one's for you pahrump......
if just swapping these out, you can do them by removing the clutch plate on teh side without removing everything similiar to the kicker.
tools needed, 30mm offset wrench or 30mm socket and breaker bar, flat tip, magnet to remove the ball inside, a dremel or drill with large bit, hammer and punch.
the stock clutch basket has a starter gear assy. on the back that is riveted on. well, turns out you need those on the new clutch assy. so i took a dremel and cut them off from the insde and punched them out from there. (make sure to thoroughly clean your parts after this because of the metal shavings)
other than getting the 30mm bolt free and removing the rivets, it's an easy job.
1 - 1 of 1 Posts
