Check for vacuum leaks.
where should I be looking ?Check for vacuum leaks.[/b]
the carb boots, with it idling, spray down the boots and carb with carb cleaner and if it alters the idle, then you have a vacuum leak, be careful around the exhaust.[/b]
The same thing has been happening to me, everytime I try to adjust the idle it just dies on me. Mine stalls out in first gear and neutral ALL the f'ing time and is a b!tch to start back up sometimes.
I put a bigger main jet in (170) with a 45P and somewhere around 3rd clip and still can't figure out why is runs and idles like crap most of the time. ??? I didn't find any leaks on the boot, but ws seaching here this morning and found something about bypassing a clutch wire. Can anyone tell me if this could be the solution to my problem?[/b]
Seems like it idles high, then when I adjust it the thing craps out on me. It sucks trail riding with the old farts on their 4x4s cause I spend most of my time trying to restart my quad. :strokin:Sounds very similar to my problem. 172 main, 45p, No airbox lid, stock needle, zip tie mod. Mine will start right back up though.
Does yours idle at a normal RPM ? Or is it high ?[/b]
Seems like it idles high, then when I adjust it the thing craps out on me. It sucks trail riding with the old farts on their 4x4s cause I spend most of my time trying to restart my quad. :strokin:[/b]
dont adjust alot at once only adjust at most a quarter turn. adjust,let it idle for about five minutes and see what it does. if you cant adjust your idle using the black nob you have problems else where. make sure your throttle line had no binds ups. spray some WD on your thumb throttle and take the cover off where the throttle cable goes in and clean that area up. all you guys have no mentioned anything about the fuel screw, screw it all the way in and start at 1.5 turns out. make sure everything is perfect[/b]
I was going by what was recommended on this forum for jetting specs. I have a 45p and a 172m HMF slip on, no A/B lid. I have a 165 as-well. Should I try that ? I live in Ma. not sure of the elevation.your jetting and clip position is weird for a stock bike. i would go 45 165 and stock needle position 2.5 turns out on screw and start it back up. go from there. the "clutch wire" shouldnt be your problem. you either reffering to the system that senses when the clutch is in so you dont start it in gear, or the TORS which will either make your bike work, or not work at all, and shouldnt affect the idle at all.[/b]
what part of mass?I was going by what was recommended on this forum for jetting specs. I have a 45p and a 172m HMF slip on, no A/B lid. I have a 165 as-well. Should I try that ? I live in Ma. not sure of the elevation.[/b]
Cape Codwhat part of mass?[/b]
If the slide is open a little (like I was giving it a little throttle) it would run anyway, not stall out right? I'll try anything though. I turn the idle screw and it dies, I changed the main jetting from 165 to 170 and it still didn't make a difference, it's very AGGRAVATING! ha ha[/b]
