Call me stupid,but I cant find the idle adjustment on the carb,where is it?
YEP THATS IT THANKS I NEED THAT TOOOriginally posted by Pahrump@Jan 15 2004, 08:00 PM
Idle Screw:
That is where the hot start cable goes.Originally posted by 03'z400@Feb 6 2004, 08:28 PM
whats the black knob on the TOP of the carb?
Yeah that's it.Originally posted by MXCOP@Feb 9 2004, 10:48 AM
Pahrump - is that the black knob above the choke that does not have a name or number on the carb schematic?
It raises or lowers the RPM at which the quads idles.Originally posted by yfz450prince@Feb 12 2004, 07:40 PM
(idle adjustment on the carb)
what this do???and why??? how???
....i am either stupid or new but what ilnow that i realy need the answer
Im not gonna attempt that!, but i figured you really couldnt tell what the rpms were at without a tach myself.Originally posted by fly'in YFZ@Feb 20 2004, 06:59 PM
put your lips together and pucker up. then take your index finger(right or left, whichever you're more comfortable with)...make a fist and extend only your index finger. while holding finger horizontally, touch it to the middle of your "pursed lips" then move your finger in an "up and down" motion against your lips as fast as possible while making a soft humming sound.
as you increase your speed, raise the pitch of your humming. If you do that as fast as you can...that will be approximately equal to 500rpm.
...p.s. do this either inside the garage or inside the house.(neighbors) :rock
