My 04 will not stop leaking coolant. It leaks from the pipe that the radiator hose is connected to. There is an o ring in there I replaced that I thought would fix it but didn’t. I changed every seal and bearing even a new impeller shaft.
It’s not leaking from the weep hole but actually where that little pipe goes into the water pump cover. And when I say leak I mean it’s hardly dripping at all. I am tempted to put some silicone on the small pipe to help that o ring seal better but don’t want to if it will damage anything. Any ideas or opinions or experiences will be helpful.
Thanks
Thanks
