hey i was rideing my 450 and it was snowing HARDCORE out and i think some snow/water got in the airfilter and it was boggy and sh!t. but it was runing fine the daybefor. then my friend started messing with the idle and now its trown way off. how many turns out are u guys runing ?
If drying out your air filter don't work, try turnning the idle screw in all the way, then back it out 2 full turn's. That will be a good starting point. Ride the qud. Only make small adjustment's at a time. (half turn's) If you've adjusted and can't get the hes. out, get it as close as you can and start adjusting the acc. pump. Good luck hope you get it back to good. :yfz
