I need help getting the proper squish
I have a 04/05 motor with a 6mm falicon crank and falicon knife rod with a spacer kit and Athena 98mm cylinder, with a CP piston, the piston is a 03-05 13.5:-1 or a 06-13 13.75:1 compression ratio so I do not know which one it will be with my set up.
I have web 943 cams and if needed I can look up the specs of the cam.
I have 2 head gaskets, one is a Athena that I measure at .049 thickness and I have a cometic that I measure at .053 thickness. both are measured before it is mashed down if that matters.
With no gaskets my piston is sticking up over the cylinder .074" in dead center and the rear of the piston is .042 and the front is .039 ( I only have one ring on so the piston is probably cocked a tad and so maybe the equal amount would be .040 -.041 ) I have the spec sheet on the piston if that is needed.
I do not know if the head has been resurfaced and the head is at MMAD so I probably should ask him to check that if it will matter.
I do have 2 base gaskets, one is a Athena and it measures .026 and the OEM measures .023
I need to figure out what size base gaskets I will need ( I will need 2 )
Any help would be great.
