there is a screw on the outside top of all the shocks which is compression setting
there is a screw on the inside on the bottom of the fronts and on the right bottom of the back which is rebound
to adjust ride height/preload you turn the spring which i believe is quite self explanatory (questions just ask)
screwing the comp sping in makes it harder, out for softer
screwing the rebound screw in makes it faster and out for slower.
take a look at the 450 garage wiki and take some time to read this. its alot, but it helped me a whole bunch
http://quadhub.com/wiki/index.php?title=Suspension_setup
