How Do You Disassemble The Front Shocks?
2677 Views 3 Replies 3 Participants Last post by  oddball64
I want to pull my stock '04 shocks apart to clean them up but don't see how they come apart. Any help....
They'res a ring at the bottom of the shock, but with a slot so it can slide off the shaft. Compress the spring so they'res no tension on the ring and just slide the ring off, get a friend to help compress the shock if you can't do both yourself. But yeh, things just start to slide off from they're. Make sure you put everything on in the same order it came off though.It's pretty simple stuff, Good Luck : )
Thanks alot. Exactly what I was looking for.
