Well I got home last night from work and my Houser stem was sitting at the door. Got everything mounted up and the +2 inch transparent red stem looks sweet. I will try to get some pics up soon.
I ordered the stem along with a oversized bar clamp (anit-vibratioin) and the bottom without the ajustable stops. They said it is going to correct bup steer.
total with shipping it was like 290. Fit and finish is next to none. The tig welds look perfect.
Is the bottom mount peice a nessecity or can you use the stock one? Also how did your cables fit? Clutch, Front Brake and Throttle is all I am concerned about.
You can use your stock bottom. You can also use the Houser bottom on stock stem.
