2017 450r
HMF performance slip on exhaust
HMF fuel optimizer
Pro design - Pro Flow K&N intake w/o a top cover
I'm noticing slight hesitation at lower rpms when rolling into throttle/light acceleration. As well as an excessive amount of backfire around those same rpms or with light blips. Mid/top end power feel fine. It's almost like having a all the boost kick in at once in a turbocharged car. Hesitation, then bang you're moving. Given that, I would assume it is running relatively rich in that particular area of low rpms. And/or the timing for midrange is off. I bought the bike as is and am curious as to what optimizer settings you would recommend with the current modifications. The current values for the correspondingly modes are as follows.
G - 7 Y - 6 R - 5. G/B - 7 R/Y - 6 R/B - 4.5
I don't really have a way of knowing what these values should be at. I'll try and do some more research on people with similar mods to get myself a baseline but any advice would be appreciated. Thank you.
The hesitation is likely in the factory ECU, but ATV on demand was able to work out the bog with their YFZ with Green/Blue 8 ; Green 7 ; Yellow 6 ; red 5; however, that could change for based on your elevation. Here's the video:
HMF YFZ450R Competition Series Exhaust and Fuel Optimizer Test - YouTube
2:45 they start to talk about tuning for the HMF exhaust
3:38 they share the settings
