1 - 13 of 13 Posts
Hey everyone, just picked up a mx yfz. It runs fine but is really lean, the curtis sparks lights up bright red and has some popping/backfiring. My mods are listed in my sig. I was hoping someone would have some knowledge/experience with similar mods. I have a ton of time rejetting the banshee so that will be a breeze, I was just wondering a good place to start. I will be riding around 500ft msl, 60-80 degree weather. 170 mains/ 45 pilots good? Any help would be greatly appreciated. Thanks, Chris
Alright man I'll give those a shot. I don't have any idea, just got the bike, haven't had the carb off yet. Thanks a lot for the tips
I've been reaing a lot on this subject this past weekend due to the fact my bike backfires everytime I let off the throttle. If you have a cam mod done you need to have at least a 48 pilot jet in. I had a 45 in mine. Haven't put the bike back togeather yet so I don't know if it cured the problem.
Jeff
QUOTE (ntenufsun @ Feb 11 2009, 05:04 PM) index.php?act=findpost&pid=745321
Jeff[/b]
I have hotcams in mine, I imagine I will stick a 50 pilot and 178 main in her and see what she does. I'll let you know this weekend how it goes
the hotcams stage one is basically the same thing as the cam-modded version of the stock cams
Your sig is huge.
QUOTE (2001Shee @ Feb 11 2009, 07:41 PM) index.php?act=findpost&pid=745473
what do you have your jets set at?[/b]
umm 3rd clip on needle 160 pilot and a 40 main i beleive. Im at 3500ft above sea level tho
and yea, can you make your sig a bit shorter or downsize your pics
I messed with mine for two weeks and then put it on a Dynotech dyno. We ended up making the best power at 46RW with a 45P 175M and the clip at the 3rd position on the NCVQ needle. I am at 300MSL and temps are 70-85 with 55% humidity. Hope it helps but dyno tuning it is a no brainer. I could post my dyno run if you want a look.
Discussion Starter · #11 ·
Went with a 175 main and 48 pilot this weekend. Runs much better but seems like there is something to be desired. I will probably jump her up to 180 main 50 pilot next weekend and play with the accelerator pump. hope that does the trick, thanks everyone for the tips
Discussion Starter · #13 ·
QUOTE (ndevall @ Feb 16 2009, 09:40 AM) index.php?act=findpost&pid=747023
Check out this thread, it might help out some. http://yfz450.theatvchannel.com/invision/i...st&p=681994[/b]
haha yeah thanks for the help man, seems like they just want to get on each other's case more than help people out.. I have the powerbowl that is mentioned in there also. The new jets fixed my noticeably hot EGTs but still seems like the power is not there.. I don't understand, I will keep messing with it this weekend and let you know
1 - 13 of 13 Posts
