The 04 and 05 models use the same harness. If I’m not mistaken, the 06 harness has more to it because the tail light connector is different so you would need to use a 06 and up taillight and the kill switch/headlight switch assembly are different as well and you would need to run the 06+ switch. I think I read somewhere that you also needed a resistor box to complete the 06 wiring harness conversion? But anyways, the 05 harnesses will work for your 04
